Cubist
Most of the finds the members of this forum come across with their properties are concerned with the sins of past tradesmen, professional bodgers, and unskilled amateurs - such as myself.
Being a recent joiner I have not read more than a small fraction of past posts recorded here so please forgive me if I am duplicating someones prior efforts - in which event please post a link to those messages.
After acquiring Fircroft a few years back we have had our share of unhappy discoveries and, under the diligent supervision of the First Lady, I am slowly correcting the sins of the past while keeping a wary eye out for our local Conservation Officer. However, several other discoveries have proven very pleasant indeed. None of these have been as lucrative as the odd Rembrandt cluttering the attic but each, in their own way, has given us a flavour of the history of the house and the people who lived here before us.
Sadly, as our house was the subject a ground-up restoration some time back, we have found nothing of note, so far, inside. The outbuildings and land on the other hand have produced quite a lot one way and another. I won't bother you with details of the dozens of bottles - booze, medicine and perfume or the continually growing collection of busted clay pipes and teapots discarded by previous gardeners. Nor will I itemise the galvanised buckets, enamel basins, and oddly a poe that have been pressed into service as plant pots in the herb bed. Bits, bridles, horseshoes, busted spades and ironwork of curious nature or use have also been rounded up with no indication yet that the flow will abate.
Amongst all this detritus though have been odd gems that merit a little more than just passing mention, these being;
1. A two man wood saw buried in the corner of a corrugated iron shed that was constructed over the old outside earth-closet.
2. A set of Avery sack scales made of cast iron and steel and obviously far too heavy for the previous owners to bother moving.
4. Four leaded and tin windows and frames discovered in a discarded 250 gallon water barrel.
3. An antique Oak internal door, complete with Suffolk Latch and Penny Strap Hinges found in a shed.
The last is clearly the best. Not least because it is constructed from a single plank and at over 30 inches wide must have been cut from a very old tree. As you may expect the door found its way back into the house in short order - albeit at the risk of a hernia - and now provides access to what we now call a dressing room.
The door may be the best find but my favourites are the pottery wren I unearthed in one of the fields and a biscuit tin full of buttons that reminded me of my Grandma's.
As I'm sure that many other members will have made interesting and/or valuable discoveries in and around their homes I thought some of them may wish to share.
So are you the one that found a Constable of the non-PC variety in some nook in your home?
