sheikyerbouti
Hi,
This is my first post on here and hopefully, i'll be able to give my experiences over the coming months.
Myself and my wife have just purchased an old property which, whilst perfectly liveable, has various issues which need sorting out. We knew of the issues at purchase so we are not under any illusions that we need to spend money to rectify.
I'll start with giving a description of the house as i've been doing my research into such things! The deeds are showing a build date of 1919, however there seems to be some features (confirmed by a listed building specialist) that date back much earlier than this, maybe to the mid 18th Century. The house has solid brick walls with (presumably) lime render. It is currently uninsulated. The floors are tile and the house has UPVC double glazing. A fresh air circulation system is in the loft and we have central heating. The house is currently rendered.
The house has an external double garage with a converted 1 bedroomed annex on the end.
Ok, we enlisted the services of a specialist in listed and period properties before committing to purchase. After taking various probe readings and getting information on the property, he recommended the following :
- To ensure that the ground level all around is sufficiently below the bell render to allow drainage.
- To rerender the property in the correct materials (lime)
In his opinion, these were the only issues to address to get the property in fine shape ready for modernising inside. He was a very knowledgable chap and I trust in his knowledge and experience.
The previous owner confirmed that the property had suffered with leaking gutters for many years which were replaced about a year ago. Various roof tiles have also been replaced which show that there has been issues with water in the past.
We moved in to the property last Saturday and are now able to get a good look around and get quotes for building work. I got a local builder who I have used before (40 years experience) and, again, whose knowledge and expertise I wouldn't question. He recommended having the following completed:
- Extend the roof overhang by around 50-100mm to help stop water running down the wall,
- Rerender in Sand and Cement - In his opinion modern day materials are breathable enough for what I require. If, however the brickwork is in good condition after stripping off the render, he would recommend the walls be treat and repointed (in cement mortar)
- Inject a DPC as the internal damp issues are rising damp. He was very insistent on this. Strip off all plaster to a metre and replaster.
- Some kind of french drain at the side of the house (this land does not belong to me and is a car sales pitch - however i'm sure some works could be done to help alleviate my damp problems)
- Repoint chimney and check flashings.
I'm awaiting a quote for the above.
Now i'm confused. I want to do this job right and feel I am appraoching it correctly - tackle any building works and make the place watertight before starting and internal fancy works! However I want to ensure the structure of the building will be correct for years to come. I wondered if anyone would like to give their opinions on what I have been told?
I've attached various pictures at the following link for your perusal - http://imageshack.us/g/84/outerhousekitchenwall.jpg/
Also, can anyone recommend a traditional builder in the Yorkshire between (Selby and Doncaster) area?
Many thanks
Russell
Many thanks
Russell
