Sue Wilkinson
- Northamptonshire
This is one of those things you wish you hadn't started. I needed a bit of wall to practice plastering a dead sharp corner (yuck) for a job I'm doing in someone else's house. I'm replacing cement/concrete and goodness knows what else for them with lime, but one sharp corner only needed to be stripped half way up the wall (they are keen to keep costs down) and so I have to match my plastering in with the remaining corner and I've always done soft corners before.
I have a bit of wall in the back lobby that I thought would be good practice, a sharp corner and all. So as the plaster on this wall was blown at the bottom I thought I'd take it off and use it as a test area.
So that job should have taken a couple of hours at most to include cleaning up. This is the 3rd day!!!!
Turns out the wall was covered in about 2" of rock hard cement. But the wall underneath was a nice red brick, single skin with good finished pointing on the passage side, so was obviously built to show. I decided to clean it all off as my husband said he liked it and would like it left exposed and lime washed. So that all came off very slowly because of the shear effort needed. Then I transfered to the wall opposite and got a practice area sorted. I would dearly love to remove the rest of that wall too, as such hard stuff has no place in my desired home, but I don't have the time. I've also hacked off inches of concrete from a stone outside wall in there, which is very wet and will benefit from lime at the bottom. I don't have the strength or time to remove all of this rock hard substance in this little space. I need a builder to help me, but can't afford one, so if I can improve the bottom of the walls I'm hoping that will help.
This passage connects with the loo, the hammering to remove the cement on the passage side has cracked the plaster in the loo, so I'm now taking that off. In the process I decided to see what was under the horrible lino, so that's gone, with the rotten tar paper that was under it and hundreds of silver fish. I'm now left with an old concrete floor in the loo. I got very excited when I realised that under that is the original quarry tiles, probably onto the earth. I found a strip of wood totally rotted away under a botched join between the passage and loo floor which shows quite a bit of the tiling. I would love to take up the concrete and bitumen in the passage and the concrete in the loo, but I don't have time yet, and the loo has been installed after the original flooring by several hundred years I expect, and there is an obvious area with newer cement round the loo and pipework etc that means the original tiles will be caput under there.
So, I have to keep the concrete floor for now. I'm getting the paint off the walls, will replace what plaster I can get off with lime and will distemper over everything. What can I do about the floor to make it look more presentable?
It's had a coat of red floor paint at some point, but most of that is off and the rest will be off soon! Can I polish it with something to make it look better yet allow it to continue to breath? Can I paint it with something that won't seal it?
After all these years of inappropriate remedies for damp down there I would like it to have a chance to dry as much as it can. One day it and the tanking and the rest of the cement is coming out, but not this year!
Any ideas?
Sue
Any ideas?
Sue
