tycarregydwr
We are preparing for our woodburner, finally, at last, allelulia, etc. We are getting a small wood-fired range (with an oven), in the living room. The house had concrete floors poured probably in the 1960s/70s, and a hideous tiled fireplace installed, which we have ripped out (lots of smashy fun!). We had lengthy talks with the stove installer as to the hearth. His initial suggestion was that we should insulate the hearth, possibly with celotex, rather than 'waste' energy heating the slab. Then he changed his mind and said it's probably not necessary with a cooker, since they throw the heat more upwards anyway. So we haven't bothered. We've laid a slate tile hearth over the concrete, the tiles are quite thin so it's only about 1/2" above the concrete slab.
This week I visited friends in their (completely and utterly amazing) G2 listed pre- and Georgian mansion, in the kitchen they have thick slates and an aga (electric). The slates were warm underfoot for quite a radius around the range, and purely as a result of it - no underfloor heating.
So my question to those of you with cold solid-ish floors and range cookers is, does the floor warm up and, is this a good or bad thing?
The stove installer said it would be a 'waste', but I'm thinking, if some of the energy goes into the slab then surely that's just the slab acting as a heat sink/thermal mass, and therefore no bad thing?
