Geoff Flegg
The title says it all really.......
I've a bay window roof that drains via a smaller than usual downpipe. The bottom section is the original 1899 cast iron, higher up it's been replaced with cast aluminium at some point, which looks fine.
What I really need is an offset bend (offset of around 70mm) - everyman and his dog sells cast iron and aluminium downpipes in 63/65 and 75mm diameters, anyone got any idea where you can obtain 50mm?
Somebody has obviously made it at some point since Victorian times since I have the aluminum sections - which, typically, have no makers mark on them!
Geoff
Geoff
