I have just got myself 300m of new oak floorboarding which I'll be using to replace the floor upstairs (the old floor is 1970s planks which are different thicknesses and have cupped all over the place). The T&G profile of the oak is setup for secret nailing but I thought screwing would be a better idea than nailing. It removes the issue of nails pulling out and makes it somewhat easier to take the boards up if there is ever any need in the future. The question then raises as to what sort of screw? You can get special screws from Screwfix:
type 1 type 2
but these are not cheap so I tried some cheap 3 x 40mm standard woodscrews on an offcut and though small, seemed to work really well. They went in flush without needing a pilot hole nor countersinking so look ideal to me with my limited knowledge. The finish is a zinc passivate which should hopefully stop the steel turning the oak black not that I would have thought it would be seen if they did due to T&G lip. The joists are approx 350mm spacing so would one 3x40mm screw (No 4, 1 1/2" I think) per joist be enough?
I also intend to use some of the boards to make a simple ledge and brace internal door but I'm completely lost as to what to use to hold it together. I guess rose head nails would the most appropriate but can you get these in a form which won't stain the oak? Where is a good place to get them or any alternative from?
type 1 type 2
