Hello there! We moved into an Edwardian doer-upper a few years ago and are slowly renovating and reinstating as we go.
I’m currently freeing up a sash window in the bathroom, which has clearly had its pulleys replaced at some point. I’ll be fitting new ones (Mighton) along with cord and re-weighting have noticed that the wood around the pulleys is a bit ‘chewed up’, presumably where the original was dug out in the past.
I’d prefer to tidy the perimeter up before finish fitting the pulleys and decorating because, frankly, I’m awful at painting and would prefer not to have to mask the pulley faces whilst filling and would probably like to be able to remove the pulleys in future rather than having them painted in.
I can’t think of a way to easily do this: I have tried using grease proof paper around the pulley whilst filling, to no avail and if I hold a 1” filling knife in the pulley-less hole and fill up to that, obviously my filler doesn’t stay put as soon as I move it.
Should I just caulk around the pulley in situ and get a competent adult to neatly decorate? Is there an added draft proofing benefit to doing this?
Or is there a cunning product/method which would enable me to fill with the pulleys out? In terms of the scale of ‘chewing’ it’s about the same as any YouTube videos which demonstrate removing old pulleys: not catastrophic but enough for her indoors to see from three rooms away.
Any suggestions gratefully received!
