Sonyaclegg
Well, we bought the doors for the house and they are all hung. I'm currently sanding with a fine grade paper and finishing off with Osmo Polyx Oil They are magnificent. However, I'm having a problem sourcing latch mechanisms. I need a latch with a non standard backset to position the spindle at 76mm. The door has mouldings on both side which take the thickness of the door to about 82mm but I can just get longer spindles made. The real problem is that to fit a handle in the middle of the moulding (52mm wide) the position to fix to the spindle needs to be 76mm. I can find bigger latch sets but then the spindle position is at 82mm. I've spent the last week on the Internet trying to find a solution.
I can fit a ball mechanism rather than a latch and then put pull handles on both sides of the doors which solves the problem entirely but I really think we should have lever handles on the doors.
Any ideas?
Any ideas?
