Feltwell
- Shropshire, England
Any of you clever bunch know much about extractor fans?
My en-suite previously had a through-the-wall wall mounted extractor fan, that wasn't that good. So, in the refurb, I thought an inline fan with an inlet fitted directly above the shower cubicle would work better. Only problem is, it's quite a convoluted route for the ducting to get to an outside wall.
I used flexible aluminium ducting and it was rather rubbish - the corrugated spirals of the ducting offered too much air resistance and turbulence in use, even with it stretched out. Very quiet but very little air passing through it!
So, I bit the bullet and re-did it all in 4" plastic round ducting and fittings. It's probably only about a 2m run in total, but it's complicated - 3 x 45 degree fittings and 2 x 90 degree fittings have had to be used, plus an anti-backdraft flap on the exhaust. Good news is, airflow has increased dramatically - bad news is, it's now quite noisy.
It's not the fan - that is genuinely very quiet - it seems to be the airflow and acoustics of the ducting. I tried substituting part of the new "solid" ducting for flexible, in case it was vibration transmission from the fan, it made no difference. It's not the inlet in the ceiling, you can pull the cover plate off that to make it just a hole in the ceiling, if anything that makes it louder!
The fan is actually in the ceiling of the room next door, in that room it's pretty quiet - it's the en-suite, where just the inlet is, that has the noise.
Now it's not unbearable by any means, just louder than I'd like. I've turned the fan speed down which does improve matters, not tried it with the shower yet but suspect it may be too much of a compromise.
Any bright ideas? I know you can get insulated flexible conduit, but it's still spiral ridged so I think I'll get the same problem as first time. I will be wrapping some rockwool around my new ducting, just to help stop any condensation.
I suspect it might just be a side effect of my wiggly route that I have to live with, but if any of you lot have any ideas, they'd be gratefully received! The route is as straight as I can make it, with 45 degree bends used in preference to 90's where I can.
