mrblint
- Pennsylvania
I'm in the US, in the mid-Atlantic area, and am in the process of bedding some reclaimed natural cleft bluestone patio slabs using St Astier NHL5 in a ratio of 2 parts NHL to 5 parts sand (by volume). We had several weeks of rain, a while back, which delayed things, so I'm only about two thirds of the way done, and the cold weather is coming. It was 32° F (0° C) last night but around 60° F (16° C) today. I'm not sure whether to continue with the NHL5 for the grout or use NHL3.5 instead. The bluestone is fairly soft stone.
The patio will receive foot traffic only. We do have cold winters with freeze/thaw. One of my goals is to have any moisture below the slabs be able to escape really easily through the NHL. Below the NHL bed is a cured portland cement sand topping base. Another goal is to mix in some pigment that will work with the varied colors of the bluestone slabs. Some are "lilac" which is like a brownish red, some are greenish, some are dark blue, some a dark rusty brown-orange like a whisky. The "concrete sand" I'm using is a pale orangy color, and I've mixed it with some coarser sand (max 3mm grains) that is beige, and when the NHL5 bedding mortar dries, it's a light ochre. For the grout, I'd like to darken it to a dry cocoa powder color, or even darker, a burnt umber, if that's even possible. I've been told to expect pastel shades.
Open to suggestions and advice, since I've never done this before.
