lukejbobins
Morning all,
We’re new to this forum and found it through a few links on another site.
So, we’ve just bought a 4 bed 18th Century farmhouse which appears to have been two buildings in its original state as we have a staircase on both the front and back of the building.
The house sits in side on to the road in roughly 0.75 acres of land with 2 outbuildings connected to the house, a double garage and a huge greenhouse which has fallen into a state of disrepair.
The main building is 2 storey (GF, 1st Fl.) with all outbuildings are single storey. The building is solid wall construction made of brick and has a concrete render to the outside at varying heights around the ground floor (rear - 6ft, side - 3ft, front -3ft). A small toilet extension has been added to the ground floor in the 1960’s which hasn’t had a concrete render applied. The roofing had a few slipped tiles (slate on one side and pan tile on the other) and had the guttering on the outside has significant damage.
The internal of the building has 2 living rooms on the ground floor, a kitchen, a bathroom and a single toilet cubicle. The first floor of the building has 4 bedrooms (2 double and two singles). The house hasn’t had any decorating done since the 1960’s and is in need of a major update. Both of the rooms on the backside of the building where the gutter damage, slipped tiles and high external concrete render have damp in the walls.
The house was previously heated by a 2 log burning fires and an immersion heater for hot water.
The house fortunately for us isn’t listed although it is in a conservation area.
Hopefully that gives a good overview of the house layout and building fabric.
So far we’ve:
1) Made good existing roof
2) Replaced guttering around the main house
3) Removed concrete render to back of property.
Our hope is that preventing water ingress and removing the concrete will allow those rooms to breath again.
Our next steps are to appoint a builder and start moving forward with the project in the new year. Key things we need opinions on before we appoint the builders are:
1) Best internal insulation methods and things to avoid.
2) Heating methods with no gas. (UFH, Log burners, Oil boiler. . .) and things to avoid.
3) Anything key to look out for.
Thanks in advance.
So far we’ve:
Thanks in advance.
