atlasfever
I just did a few searches on this site, but didn't quite see a similar question: Glazing and a Period property
Background: Grade II listed building
An architect suggested that it's feasible to install new thermal/double glazing panes into my double sash windows, using the existing glazing bars. I was rather surprised to hear this, as I assumed that one could never 'touch' the original windows (with the exception of maybe fixing the wood carefully, or I suppose, replacing a broken pane with a single glazing pane.
Could this be true? Even if the new glazing technology is super slim and makes it technically and visually applicable, I am surprised one could get consent for this, especially on the front of a building. Perhaps different on the rear. By the way, I have double sash windows, with 12 panes of glass each (1st floor of building, so very tall windows).
Additional question: I know this is a long standing debate and I don't want to be too philosophical, but I would really like to educate myself: In today's world of learning to be enviro friendly, I'm a bit surprised that there isn't more of a push to use double glazing (assuming the panes are thin, attractive, etc). It is the belief that adding a secondary glazing inside the flat is enough to sort it out, and so you should keep the original outside, but then install double glazing panels inside? Ie. It doesn't matter if it's unattractive on the inside, but the outside should remain attractive? That's all I can figure out, b/c the tremendous waste of resources (money or heat) is rather sad. I guess I can understand the value of keeping crown glass, but otherwise, maybe the technology of the original window is in fact outdated for good reason?? Just thoughts -- Open to more opinion. Cheers
