SilverSaloon
- Fife, Scotland, UK
Hi
I need to replace my timber floors throughout my stone-built 1850's cottage due to there currently being no void under the floorboards so the joists are rotted though/eaten by the worms.
My plan is:
- dig down to outside ground level
- add airbrick vents in various areas
- and add sleeper walls around where the end of the joists will sit
- fit new timber joists and boards on
I've done a good bit of research into the methods advised but these dont seem to take into account older properties.
My original plan was to:
- after digging down, level with some sand, and then lay a polythene Damp Proof Membrane sheet across the whole void, going up the sleeper walls.
- putting a thin layer of concrete over the top of the DPM.
However I'm worried about moisture then being forced up the walls.
Should I leave the void to just have some sand on the top of the earth and not install a DPM? should I install a DPM without the concrete, with maybe some shingle on the top?
Any advice with an older property in mind would be appreciated! I will be doing all the work myself by the way, no builders involved.
thanks
Derek
My plan is:
thanks
Derek
