Hi, we're just about to buy a victorian detached house. We are going to be knocking together two rooms and adding a small extension to make a bigger kitchen. One of the rooms has what we have been told by the surveyor is a victorian (so not concrete) solid floor. He's explained that the terracotta tiles on the surface act as the damp proof layer. The other room has a timber suspended floor. We want to take up the solid floor terracotta tiles, and lay a new parquet floor across the whole of the new room, levelling out the various floor surfaces, so we can link together the three areas, but I'm not sure what to do with the solid floor.
The house has some problems with penetrating damp, mostly due to massive neglect, leaking gutters and a layer of cement render that has been added to some of the walls which water is getting behind. We plan to remove the render and repoint with lime mortar and use lime plaster inside to regain breathability. The timber and damp surveyor (independent so not trying to sell us anything) did suggest injecting a DPC, which we don't plan to do as I feel it causes more problems than it solves. He also suggested that if we removed the terracotta tiles we should add a layer of something called Oldroyd Xs to create a damvproof membrane to the floor. My worry is that by changing the characteristic of the existing floor we may cause damp problems to the walls.
I was just wondering what everyone though? Is this the right way to proceed? IF not, what would you suggest?
