Cloudscape
- Mid-Wales
I recently bought an old Grade II place - stone walls, slate roof, quite a bit of exposed timber inside. (Just a sample, before we bought the place)
Whoever had the house... before the people before us... seemed to be going along the right lines. There are lime-plastered internal walls, and (I think) limewash. Some of the lime plaster is signed by the plasterer, back in the 1980s.
If any of the older internal doors aren't actually old, they look it. The choice of door furniture is very 'authentic', in iron, with rosehead nails. All this looks great and makes you feel that at least some people understood what they were doing.
Unfortunately, the owners before me, used gypsum plaster extensively, plasterboard, and (now I've found where they dumped all their unused paint and empty paint tins!) lots of vinyl emulsion. There are even a couple of unopened tins of F+B paint - which indicates the spirit was willing... but this paint was never used.
They have part dry-lined and/or plastered two rooms, covering what was alledgedly very nice exposed stonework (by plastering directly onto it). Luckily they moved, they only got as far as 'modernizing' two rooms.
The living room is plastered almost completely with gypsum plaster. There are two areas of damp on an external wall (seems to relate to the heat generated by a wood-burning stove). Should I take all the gypsum plaster off and start again?
How easy/hard is it to get gypsum plaster off stone walls?
Where walls have been emulsioned, is it possible to sand the paint off? Does this damage the lime plaster?
Externally, round the back where the walls have never been limewashed, the previous owner proudly indicated quite a lot of repointing... all in cement mortar. It's everywhere, locally. :?
Should I leave the pointing as it is? It's neat, if nothing else. Or should it be removed? It's all one one two-storey gable end at the rear.
Never having owned a listed building (and having read of other people's experiences with COs), I feel I should tell the planning dept before I even refurb the roof and chimneys, let alone change anything. I'm even wondering if I should get permission to lop some trees in my back garden. :?
If listing is about the 'character' of a house, are you allowed to choose whatever style bathrooms and kitchen you want - given that these rooms do have 'character'? This is may be a daft question, but the kitchen is very visible from a very 'period' dining room. If I make the kitchen very modern, doesn't this effect the character of the house?
There is a mix in the house of lath/plaster infill to timber framing, plasterboard infill and... no infill at all. Our surveyor said that some of the open framework should be filled. If this is for strength, should it be lath and plaster? Is plasterboard infilling OK?
Some of this infill is very raised - either as smooth cushions of lime plaster, or very rough ones! It seems to stick out more than would have been necessary to cover the laths (nailed between the timbers, on the surface). Does anyone know if this raised infilling is functional or just because it looks interesting? Could you inset laths onto battens and have cushions that were only slightly raised (or not raised at all)?
Oh... and roughcast render. It's been on the front of the house since at least the 1880s (seen in old photos). It's been patched and doesn't look too bad. But one area (maybe 0.25 sqm) is missing. What was roughcast render made of (Wales/Shropshire, probably mid 1800s)? Does anyone still do it, and can it be patched?
I have plenty to keep me going while I ponder this lot, but I'd be grateful for some info and ideas. I'm busy scraping sheep droppings off external floors (don't ask) and trying to turn back time ten years to when the housework stopped. :? I'm also scraping food and dark grease off walls, floors, radiators and even ceilings... and there's all the furniture and rubbish that was left behind. That'll keep me busy for some time.
