plasticpigeon
- Birmingham
Hello, I will soon be embarking on making the loft of my house a useable space, mainly for storage. I'm not too bothered by regs as it will not be a bedroom or living space, but having it clean, with a floor and with lights would be nice. At the moment the ceiling joists are 3 x 2 and the ceilings bow considerably. I have been up there but it is necessary to put boards down as I shuffle about to stop the floor bowing even more and cracking the plaster even more than it is already.
I have decided that the best course of action is to build another floor above with bigger joists, say 8 x 2s or something like that. I am hoping I can then tie the original ceiling to the new joists to stop movement and then repair the lath and plaster. I think the 2 best ways to put in the new floor are either to screw a wall plate into the party walls and span the house (around 15 ft) hanging the joists off joist hangers hanging off the wall plate, or alternatively, chisel out a section of mortar every so often and glue joist hangers into the party wall that way. The second method sounds better to me as it is less destructive as no holes are drilled in the wall. Also the weight of the floor will be taken on the bricks and hangers rather than on the screws holding the wall plate onto the wall. I'd be grateful for thoughts, advice or other suggestions. Many thanks.
