Hi there
We are at the tail end of having some rather major remedial work done on our c300 year old non-listed cottage. Basically we purchased the place and round that the timber soleplate sitting on top of some brick plinths had rotted. After getting specialist advice we opted to remove a c.1970 concrete floor that was pushing damp into the walls, re-instate a suspended timber floor (with adequate ventilation), re-built the brick plinths with 2 dpcs (one at the base between the what was left of the old plinths, and one slate dpc one course below where the new oak soleplate was to sit), and then a new soleplate sitting on top of some lead. On top of that we have re-plastered as there was considerable damage to the studs. All of the plastering and brickworks has been done in time to prevent issues with trapped moisture in the future.
We picked a local specialist in old buildings who came highly recommended and we have been largely very pleased with the work. I do however have one concern. The brickwork was done between July and August and I am noticing that there are still some areas where the lime mortar joints are very crumbly (but dry); I would describe it almost like sand as even if you brush areas lightly you get small piles of granulated mortar on the ground. Is this to be expected? I realise that lime takes a long time to dry, but I was not expecting crumbling, even localised. My understanding is that they used a 1:2:1 gauge (lime: sharp: sand)
What has added to my concern is the following: separately I have had a fireplace repointed using a ready mix lime mortar from a well known supplier in Devon. This work was done later and there is no crumbling on the surface of the mortar joints.
I am going to speak to the contractor about the issue some more, but I just wanted to get a sense from this forum for if this is an issue and what could have caused it.
