meljones35
We have to decide on a heating system for our cottage. There is nothing at present. No real garden and very close neighbours. Any suggestions?
AMc said:If you want greener heating and can afford it then there are also log boilers (a.k.a wood gasification) and pellet burners. These are comparatively expensive to install but are potentially much greener if you have local supplies for the fuel and they work with radiators which suit smaller rooms and older houses with higher heat demands.
AMc said:Bear in mind that the cost of electricity tracks the price of fossil fuels so if oil or gas gets more expensive so does electricity.
If you're off mains gas and don't have space for a reasonable water tank/thermal store than you're going to struggle with options on most systems.meljones35 said:Its a tiny cottage with no room for a water tank of any kind. Please keep your ideas coming!
I've been told bore holes for GSHP are in the £2k to £3k mark but I've no idea if this is accurate. Our heat pump is about the size of a small fridge so not too bad. It does make a bit of noise though and ideally should be kept outside the main house in a garage or similar.AMc said:GSHP with boreholes works - the bores are expensive to drill and the internal equipment is more bulky than a conventional boiler MdB knows more about that than I do.
I was quoted about £20K for a GSHP with 4 boreholes - the GSHP system was about 6K of that leaving about £14K for the boreholes - this was back in 2007.MdB said:I've been told bore holes for GSHP are in the £2k to £3k mark but I've no idea if this is accurate. Our heat pump is about the size of a small fridge so not too bad. It does make a bit of noise though and ideally should be kept outside the main house in a garage or similar.AMc said:GSHP with boreholes works - the bores are expensive to drill and the internal equipment is more bulky than a conventional boiler MdB knows more about that than I do.
