Hi
We're going to be sorting out our basement (converting it into living space) and have some questions about floor construction. The current floor is quarry tiles and very solid and flat. It has been down for 120+ years and is in really good condition but is not suitable for our conversion as there is no DPC. We dug some of the tiles up and they are just lying directly on the ground which is a sand/sandstone type of earth. It looks like about 6 inches of compacted sand lying on the natural sandstone rock that is everywhere in this part of the world.
We don't want to lose too much height so we considered digging the floor up by about 200mm and laying a new concrete base (100mm) then DPC then insulation (50mm) and putting a floating chipboard floor over this to bring us back to the original floor height. I believe this would be a fairly standard approach.
However when we have dug down to explore it is clear the house has no footings - it is just built directly on the sand/sandstone earth. Our architect reckons if we want to dig down we'd need to underpin it first, so recommended we don't bother. His suggestion is to either
1) Lay a DPC over existing floor, then about 25mm of insulation, then a floating chipboard floor on top of that. We'd lose about 50mm of height.
2) Dig up just the tiles, level the sand base, put 25mm of insulation on it, then a DPC, then a floating chipboard floor on top. We'd lose about 25mm of height.
What's your thoughts on these suggestions? We prefer option 2 because of the height issue but I am struggling to get to grips with the idea of a floor that is just a load of polystyrene laid directly on the earth with nothing "solid" and no anchoring... but maybe I'm just too used to seeing concrete everywhere?
Cheers
Chris
Cheers
Chris
