Athers1971
We are looking to convert what I am guessing was the old pantry or storeroom into a utility/down stairs bathroom. It was an addition to the main house at some point, and has 60cm walls on three sides as you can see from the below.
The current electrics and plumbing are bodge jobs and I'm not even sure what is going on with the solid floor underneath the 'lino' yet. It's currently home to our fridge/freezer, washer and dryer.
We want to carve out a small bathroom at the end of the room by putting in a 100mm wall, this will then house a toilet, basin and walk in shower.
The shower will go in the bottom left corner (in the pic below).
Any suggestions how one would be approach the solid walls, in particular the where the shower will be? Pretty sure the external and internal wall have a cement based plaster. Is it worth while knocking off and lime plastering if we are going to tile over it?
How about the hot and cold water pipes? Would it be better to create a thin cavity wall up against the gable end to conceal the pipes, or is that going to create other issues? Leave the pipes exposed? Try and chase into the wall?
Any other tips fitting a bathroom in a period property?
