paulbandler
- Oxfordshire
I have just aquired a small 1920's detatched house that requires extensive modernisation (including adding central heating and rewiring, new bathroom, etc). It is empty and I will not move in for another 2 months so I want use this time to undertake as much disruptive internal works as possible
Whilst generally in good condition for its age, it has some damp in lower walls that I want to address as completely as possible. I spent much time reading this and other sites on the net about damp, and have also had a survey and quote from a local damp/rot renovation specialist (who unsurprisingly recommended a chemical DPC and replastering). I am willing to invest in this if it is the best/safest option, but I am still unclear and confused by some things, hence this post...
The property is rendered. Beneath the bellmouth is a particularly hard smooth cement based render that extends to the ground in places. Concrete slabs abut the wall and in some areas these slabs are as high as the DPC. In some areas the hard render is clear of the ground for a few inches and there is evidence of earlier repointing of the exposed brick at the base. Yesterday I went looking for a DPC by lifting some floor boards close to the wall where damp is evident and cut off some of the external lower hard render. From the inside I found what I think is a bitumen impregnated flexible material protruding from a course of bricks above the air vent that I take to be the DPC. From the outside I found a corresponding black line at the same level - i.e. I think original the DPC is there where it should be but bridged by the hard render which in some places extends to the ground.
It seems clear that it would be a good idea to remove the concrete slabs that abut the wall and install a french drain to stop the damp 'wicking' up into the render. But what else...?
Q1. Should I remove the hard render to stop it bridging the DPC? The small area I removed yesterday using an angle-grinder to make cuts and then block bolster was not easy and damaged the face of the underlying bricks. I've read elsewhere of concerns over such an excersize (although also found that an SDS chisel hammer was effective). However there are some areas where this hard render can be pulled off easily - indeed I did so and exposed a large area of rough bricks in needs some kind of protection - should I re-cover it with new render, re-bridging the DPC there...?
Q2. As an alternative to removing enough hard render to stop it bridging the DPC, would it be enough to remove just to stop it going right down to the ground?
Q3. Should any such exposed brick at the base of the wall be painted in a black bitchumen paint? I've seem this (well some kind of black paint) on the base of many house walls, but would it not have the effect of sealing in any damp?
Q4. It seems reasonably clear that the bridging/ground height is the cause which will be fixed, but is it still worth investing in injection and water-proof internal replastering? I only want to do this once and I need to make the decision now to make the most of the building being empty. OTOH, I'm wary of the internal disruption to the skirting and some plaster that is in otherwise good condition.
Thank you for reading this post, and thanks in advance for any advice.
