This is the staircase leading from the first to second floor of my Georgian terrace.
The small landing on the second floor is part cantilevered, the failing of which I think is the cause of the rotation of the top half of the staircase (the top half being the upper steps, facing you, that you can't seen in the picture below).
The problem is, I think, that the timber supporting the landing is failing and due to the lack of support the top part of the staircase is coming away from the wall.
Upper landing, second floor, you can see the extent of the sloping:
Here's the damage caused due to the stress of the stairs coming away from the wall:
From what I'm able to gather myself the joist just visible in this picture
forms the edge of the cantilevered upper landing. This joist in turn is supported (I assume) by this timber beam, which is partly visible from the first floor landing shown here:
The wall to which the wall string on the top half of the stairs is fixed is timber framed. Although I have yet to inspect the timbers myself I can confirm that the wall isn't brick. You can see in these pictures that some movement has occurred where the wall bulges out over the wall string. I guess this timber framed wall isn't really helping to support the staircase.
There is cracking to various degrees the whole way around the wall string.
I suppose the way forward is to find a decent carpenter who knows is way around old buildings.
If anyone has any observations from the photos, they'd certainly be most welcome. We're not using the second floor at the moment but the space is urgently required.
