I live in a mid 19th century property where the main 30ft long living room has exposed and sealed 7" wide x 1" thick floorboards. There is a void of about 18" under this floor which looks down onto exposed dry earth. The floorboards are not tounge and grooved and there are smallish gaps between the boards ranging from about 1 to 3 mm. My problem is that this living room regularly has an earthy, musty smell which I believe must eminate from under the floor. This smell is generally only noticable when you first step into the house and lessens as your nose gets used to it. It is however particularly noticable on windy days when I pressume the increased air flow though the air bricks blows the smell up into the room. All the underfloor timbers where professionally spray treated about 2 years ago and some joists were replaced. Is this a common problem on properties of this age and how can I irradicate it? Trying to seal the small gaps between boards would be a difficult process and in any case I would like to access the floorvoid from time to time to check on timbers and under floor services etc. Heavy carpet and underlay would perhaps solve the problem but would defeat the beauty of the exposed boards. is there perhaps an infill or insulation that could be laid in the floor?
