Since getting a survey on a mid terrace Victorian house we are planning to buy, I have driven my girlfriend crazy by researching to death how to deal with damp in an old house.
This led to the decision to get another survey done by an independent damp surveyor who highlighted the following issues:
Outside ground levels slightly higher than internal floor, council pavement to front (so doubt I can fix that one).
Rubble in walls believed to have breached damp proof course in walls
Timber floor previously replaced with concrete forcing moisture to concentrate at walls
A failed (surprise surprise) injected damp proof course in stone fronted front, rest of walls believed to be old brick.
Brick third party walls in garden attach to house walls.
Pointing and flashing need fixing in chimneas (shared with neighboor x 2).
Stone window ledge bringing in moisture upstairs and down (hopefully easiest fix)
Poor ventilation, loft has almost no ventilation and is full of rubble with new non breathable felt (hopefully another more strait forward fix). No extractor fans and fireplaces x4 poorly ventilated if at all.
All party and exterior walls I'm told are very damp as is all wood near floor level in proximity to these wall.
Oh and exterior re-pointed with concrete (opps), then covered by silicon.
House viewed in summer and did not feel that damp, salt stains visible on fireplace.
We will have to pay for work as we go so blitzing it is not an option, but plan to remove plaster before moving in.
Putting in vents, sorting loft and opening / venting fireplaces likely to be first priorities.
Damp specialist advised using a breathable membrane across floor and up to downstairs ceiling height, then re-plastering, etc. He said he saw little benefit in using lime plaster and didn't exactly have much faith in other options.
This leaves me with several initial options:
1. Do as advised by damp surveyor, but walls stay wet and cold as cant breath in or out. Use of drylining dot and dab ):
2. As 1, but with hemp lime plaster for the fun of it to help with insulation and condensation.
3. Remove plaster (GF won't let me wait a year for them to dry), inspect further and apply a horse hair lime plaster to the walls down to the concrete floor (never done this but can give it a go). Leave out skirting or anything that might go bad with damp. Put in ventilation+++ and hope that this allows the walls to breath internally enough to eventually reduce rather than increase moisture in walls. Then in event this fails try idea 1 or 2.
4. Put in breathable damp proof membrane in floor with some sort of ventilation to outside (do drilled holes work?) before covering with insulation and some sort of natural carpet (seagrass?) Lime plastering walls so they can still breath out some moisture.
5. As 4 with perhaps 1 metre of breathable damp proof membrane, so top of walls can still breathe to address penetrating damp. Lime plastered over.
I have contemplated paying someone to remove rubble from walls ( Were these old houses designed with rubble infill?) and will sort chimneys, windows and ventilation regardless. May also look at reducing outside ground at back, but cant change damp coming through party walls or council owned front realistically /:
If I can make the house breathe again, even with just one lung would be happier than sealing it off, would appreciate any input on my ideas or if someone else has a better one.
