A
Anonymous
Guest
We are plannig to install our multifuel stove using the rear flue option, with a 90 degree bend to connect to the vertical stove pipe. The stove pipe has a soot door in it. I've now read somewhere that 90 degree bends should be avoided as they will inhibit the flow of the flue and that if you must install one, it should have a soot door. The argument is that a soot door on a vertical pipe is useless because the sweep won't be able to brush through it.
Grateful for any advice and experience out there on this - I wonder, if they are of no use or shouldn't be used, why you can buy the 90 degree bend and stove pipe with soot door? Also, if you can't sweep through the soot door on a vertical pipe, how can you sweep through such a door on a 90 degree bend which is only inches from the floor?
