We are just in process of buying a victorian two up and two down cottage with a staircase running in the middle of the house between lounge and dining room dividing it in two halves. We thought about opening the space downstairs and moving the staircase to the hallway. We suspect (!) one of the walls next to the staircase may be a supporting wall... although it is just a speculation...
Is it possible to move the staircase at all? if it is a supporting wall how much does it cost to put an alternative support so we can open the space? Do you know properties where it has been successfully done?
Thank you for any advice.
Best wishes,
Anna
Best wishes,
Anna
