I've read with some interest many of the previous threads on rising damp and disparaging remarks about the value of a chemical DPC. I have been trying to solve a damp problem in my house for the last year. The house is around 70 years old. I was keen to be certain of the diagnosis before embarking on expensive and disruptive reparations. The damp (and susequent mould) has appeared in the same place at opposite sides of the house, both at floor level and in corners. On one side of the house this affects adjacent corners of two different rooms (common source seems likely).
I initially thought that the damp in these rooms was secondary to water ingress around the chimney lead flashing - this was clearly a cause of water ingress and was replaced about 9 months ago. Unfortnately the associated damaged tiles were not replaced at the same time but been replaced now (2 weeks ago). There is brown water staining on the (new) plasterboard above the fireplace but this has dried. The fireplace is on the same wall as the damp. Between the fireplace and the damp corner is a built-in cupboard. I have removed this. At floor level nearest the brick work, the floor boards are visibly damp. The plywood back of this built-in cupboard has wrinkled from chronic damp exposure - worse at the floor level. The brickwork behind the cupboard is only one-layer thick (125 mm) unlike most of the other walls which are around 315 mm thick (with a cavity, I think). The outside wall is rendered and apart from a few bracket holes from an old (now removed) down-pipe some 3-4 metres from cupboard wall, the render is intact and solid. Under the floor, I can see a slate based DPC which is reasonable condition but with at least one or two gaps (air where slate should be). At the base of the chimney stack at the solum level, old rubble/ash has been heaped up and could be bridging the DPC. This could cleared away without too much trouble.
At the other side of the house, damp is occurring in exactly the same place behind an identical built-in cupboard. Again this is next to an old fireplace but on this side, the chimney has been removed (only visible in eaves) and the gap in the wall plastered over. Again under the floor rubble in contact with the external brick work.
You might say that I have identified the cause of the damp but I'm still not sure. Possible causes:
1. Defective DPC in single layer brick-work behind cupboard. Previous threads say this is unlikely.
2. Condensation. I don't buy this. These rooms are not in use, are heated and are not near bathrooms or kitchens.
3. Rubble in solum space bridging DPC and preventing air circulation.
I have unfortunately just ordered DryTech cream to perform DIY chemical DPC (only £120). I was quoted £2500 for damp-proofing (plus 25 yr guarantee) for chemical DPC and re-plastering so I am relieved that didn't go ahead with this work.
Comments please.
D.
Comments please.
D.
