I have a small concrete ramped area outside my back door about a meter square which I wish to tile over with a few left over 6” terracotta floor tiles. These are plain unglazed terracotta tiles about 20mm thick that have been treated with multiple coats of double boiled linseed oil (Leftovers from an old bathroom floor project). I also have about half a bag of left over NHL3.5 which I would like to use up. Would this lime be suitable for laying and pointing the tiles? I need to achieve 10mm wide pointing in a similar fashion to brickwork.
Because this could really be described as a ground works project, I’m guessing that NHL 5 would probably be more suitable, but being a bit of a miser, I would like to use up what I’ve got. The ramp is in quite a protected position with walls on two sides and a roof overhang and it has a slight fall away from the back door so it should never become totally saturated, nevertheless, I want to use the lime to protect the tiles from any potential water ingress and frost. I do however need to consider the strength of the mortar with regard to withstanding foot traffic. Do you think I can get away with the 3.5?
