A
Anonymous
Guest
I am looking into solutions to insulate my rubble walls. I wish to use homatherm and put it into timber studs. I reaise that I will nead an air/vapour barrier between the timber studs and the plasterboard. Do I need anything between the insulation and the cavity before the external wall (which will be rendered? Also what is the best way to attach the timber stud to the existing wall?
