I broach this topic with some trepidation as a read through of previous threads suggests that I think I know what the answers will be.
Some background:
In one of the ground floor rooms that will soon be a kitchen the external wall is only a single course brick wall and much of it has been rendered internally in a hard cement. Removal of the cement render wasn't really an option since the force needed to knock it off would have almost certainly taken the wall down with it. The wall is a real hodge podge of different bricks and repairs over time. The internal face of the original bricks are visible in a small section of the wall but not enough (I think) to allow the wall to breath effectively. If we could do the work again we would likely knock down the whole wall (it is only about 9 sqm) and rebuild it properly rather than trying to keep it and increase the size of the window aperture. But we are where we are...
I have repointed the worst areas and levelled out and consolidated the external face of the wall with NHL. The plan is to insulate externally with 40mm of cork insulation and Warmcote/Limecote render.
And now onto the contentious IWI question...
It was suggested to us during the installation of the new larger window to install an internal stud wall
as it would allow for insulation and the ability to properly fix shelves, cabinets, etc to the wall if we so wished (the window is installed in the brick wall, not the stud wall). So at the moment we have an exposed 3x2 stud wall on the external wall and party wall. I am loath to pull the stud wall down but at this juncture it is an option, I suppose. Of course if doing it all again I would fix cork/wood fibre to the wall internally...
Keeping in mind that there will be 40mm cork EWI I have come up with the following insulation buildup for the external wall. Your thoughts and advice would be most welcome. I appreciate that the answer to this is largely a known unknown - it might work, it might create problems - but I am hoping that a solution can be found that will allow me to work with what we have at the moment rather than taking a step backwards and starting again.
Some background:
- OUTSIDE
- 20mm Warmcote/Limecote render
- 40mm cork insulation
- Single course brick wall
- 80-100mm Thermafleece between internal studs
- Airguard Smart Vapour Control Layer - fixed to stud wall with battens and corners and gaps taped
- 25mm flexible wood fibre insulation between battens
- 11mm OSB board
- 15mm wood wool board
- Lime plaster
- INSIDE
