A
Anonymous
Guest
I have a croft with a house and steading built from granite boulders with lime mortars and renders. I repair these with lime but have one problem - and that is durability in the areas where livestock are kept.
The byres are lime rendered internally to a height of five feet, but the pigs in particular are fond of digging the render out, and often the lime mortar between the boulders as well. I have to spend at least a day a month making repairs and would rather spend the time doing other things!
Is it possible to get a harder mix without using cement, or should I just bite the bullet and use some cement in the render. (Bear in mind that above the render, the boulders and mortar are exposed but as that's above animal height it's not a problem as far as durability is concerned.)
I can't use board (like Sterling or marine seven-ply) to protect the render as pigs and sheep tend to nibble on them, and I don't want them ingesting formaldehyde and the like.
Also, has anyone else had a problem with rats eating the lime mortar out? While we have a constant war on vermin, I'm continually find tunnels and overhands gnawed through the mortar by rats.
Any advice appreciated.
