tumbledown
- Suffolk
I know this subject has been covered quite a few times, but I've been given a slightly different theory from a builder advocating concrete floors, and I'd appreciate people's opinions on it.
This builder is quite experienced in timber frame repairs, and I've seen examples of his work, which looks good. He is also experienced in using lime products, and repairing wattle and daub. I was therefore expecting him to advocate the traditional method of bricks/flags straight onto earth/chalk etc. especially as he had already commented on removing cement renders and lowering ground levels. Anyway, his comments on floors were:
"If you don't have a floor with a DPM, any mats you lay will constantly suffer from mould and damp, as will the bottom of any heavy furniture. The best thing to do is to lay a concrete floor with a DPM, but do not continue it right up to the walls. There should be a small strip of breathable material between the floor and the walls. In this way damp is not driven into the walls because the walls are isolated from the floor.”
So there you have the theory. I have heard the ‘damp mats’ theory before. But if there is enough moisture coming out of the floor to make your mats go green, then why would this moisture be able to escape harmlessly through a small gap around the edge of the floor? Surely the moisture would simply be concentrated and you get a damp strip around the edge of your floor. and after all, most people place there be furniture around the edge of the room, so wouldn’t the ‘trapped moisture’ problem be worse not better? I’d have thought that the only way this builders theory could work was if the DMP was continued through the walls (into the brick plinth below the soleplate), so that the moisture could evaporate outside the building and not raise up through the floor or the walls?
Anyway, I’d appreciate peoples opinions. I’d just about convinced myself that the fully breathable floor was the way forward, but this has made me wonder. Oh, the other thing he said was that a concrete floor was much better for fixing new stairs and internal walls, which was more difficult otherwise
