A
Anonymous
Guest
In my 1-bedroomed cottage, built c.1697, Rising Damp has been detected by a local surveyor using a hand-held 'moisture' meter. My estate agent instigated a survey from a local d.p. 'specialist' contractor, who used a similar device to gain readings "off the scale" & gave an estimate for remedial work in excess of £1,200. During this time, I was abroad for 6wks & neither survey was undertaken under 'normal living conditions', so I instructed my daughter to use a dehumidifier which I was sure would correct any high readings. For some peace of mind when home, I had a local builder check roof timbers & for dampness (he used a 'moisture meter' too!) His findings were in different areas to those of the 1st contractor - he believed that some were probably due to condensation, given the age & history of the building - estimate for remedial work, £352.
I'm perplexed & challenge their findings because there isn't evidence of any dampness anywhere in the property - visual or otherwise. I've visited your website, 'ask-Jeff.co.uk', Royal Insititute of Chartered Surveyors website (RICS article: Moisture Measurement in Masonry - Guidance for Surveyors.) & others & found similar articles questioning the accuracy & appropriateness of using such moisture meters.
From her surveyor's & 1st contractor's advice, my prospective purchaser is now reticent to take the risk of buying the property, & I can understand her concerns! Am I ever going to sell with this on-going problem? RICS advice is for me to consult an independent RICS surveyor, so I contacted one today but was told by a member of staff that they use 'moisture meters' & recommend work by 'Stoneoak', a local contractor - Oh, No! was my immediate reaction - said I'd call back, if necessary.
It's my belief we're being mis-led by all parties concerned - I'm reluctant to have any 'remedial' work undertaken if it could prove detrimental. I wonder how many home-owners have paid for unnecessary & costly work to be done? Homebuying reforms could probably be helpful in my situation.
I'd welcome suggestions & comments, please!
With thanks,
Lynn Whittaker
With thanks,
Lynn Whittaker
