I have a 1900s cottage with a tall slender chimney stack (three bricks by two and a half) which rises about 15 feet from the eaves. From ground to the top of the pot is about 30 feet. I plan to re-point the brickwork and line the flue with a metal liner (for a wood burner). The lime mortar pointing is generally ok but the top 3 feet has seen considerable erosion and needs seeing to. While the scaffolding was up I thought it appropriate to re-point the whole stack rather than just attending to the top and the lining.
When standing on the scaffolding and attempting to remove the pot, it became apparent that, with very little effort, I could make the whole stack sway. There are no obvious cracks and the stack is straight and perpendicular. We have had recent gales and there did not seem to be a problem, although I have always been concerned that this stack would be vulnerable in high winds if I didn’t attend to the pointing soon.
Is a mobile stack normal? Will re-pointing with lime mortar reduce its mobility or should I be planning to rebuild it?
