purplemonkey
hi,
Over the last few weeks I've been reading up on how to use Lime products, but it mostly leaves my head spinning. Based on the available information I can see why people simply stick to cement! however I am starting to repair some failed brickwork in my property and I want to use lime mortar for this job.
so here's my scenario, I bought a 25kg bag of NHL 3.5 (powder) and a 20kg tub of Lime putty (a white putty). my thinking being I'd try them both out, to see which I prefer.
my question though, how do I mix them up correctly.
First off I'd try the the bag of dry NHL 3.5
1. I put one measure of nhl 3.5 into a bucket
2. added little water and mixed till it was a malleable ball of putty
3. then I added 2 measures of sharp sand to it, mixed it up, and it looked like a good mortar.
4. I've put one brick down with it and left it over night, and its looking pretty good (to my lime untrained eye).
Using this method, I am assuming the lime putty would put me at stage 3 instead?
The main question that keeps reoccurring in my head is I keep reading bits of info saying you should mix the lime/water and leave for at least 24 hours?
Thanks in advance for any advice you can offer.
