We have just purchased a rather large mirror (122" x 86") which has a very large carved frame...resulting in a very heavy mirror.
I had planned to hang the mirror from the picture rail with picture wire, but the instructions with the mirror expressly advise against hanging on a single hook and instead suggest using two separate hooks on either side of the frame. The problem with this however, is that the wall is l&p and i don't really want to try and fix into it.
Any thoughts? I'm wondering if the instructions are guiding against a single hook on the assumption that this would be in the wall (and that there would be significant weight on a single point). Obviously, the picture rail is better suited than a single hook.
If you really think that I should fix into the l&p....does anyone have any recommendations for fixings (for very heavyweight use)?
