Penners was asking and I know how you lot like pictures....
Lintel in position. The piece of wood is required as the stone at the right hand end of the fireplace has crumbled meaning that there is nothing for the lintel / drills to rest on.
Removal of the stone that definitely isn't going to stay in place.
Removal of drills. Don't anybody sneeze. Whilst removing the lose stuff, it became obvious that the large stones on either side hadn't been supported at all for the last year (though they could only have dropped a mm or so) so I wasn't too worried that anything more was going to come down. Probably not the cleverest thing to do but I judged that if it did fall, not much would have come down and I was careful not to be underneath it.
New temporary wooden lintel in position and all stones chocked.
The removed mining drills. Our cottage is within half a mile of two sets of mine workings. I had always thought that our cottage was a farmers cottage, but these drills show that it was more likely to have been a miners residence. Although it isn't too obvious from these photos, both the drills have flattened chisel ends which would most likely have been reformed daily at the smithy which is two doors away from us. An interesting find anyway.
My plan is to clean this drills up a bit and then get a steel lintel made up that will support both the stone work above and the drills in roughly their original position. They just won't be doing work as lintels as they really aren't long enough.
