Hi
I have a late 1700s timber-frame cottage which has an external render applied to an expanded metal lath (EML). Since I've owned the house there has been a crack on the rear of the building. It opens up as the weather improves! I suspect that either the EML has become detached from the stud work or the render has become detached from the EML. The actual frame (which is exposed on the inside is relatively ok. i.e. it has suffered some movement over the years but there is no signs of movement inside since recent decoration. So what I mean by this is the crack has been filled and has opened up on the exterior, but the interior decoration does not show any new gaps - so I don't think the frame itself is increasingly bowing outward.
There is another problem related to this which is the window frame in the same wall. It shows signs of movement and a gap has developed between the frame and the internal casement/finishing panels. I actually spoke to the guy who installed these windows, he grew up two doors down and ended up being a carpenter, he's now in his 80s and thinks he put these in around the 1970s - so I didn't push the question of warranty
I am tempted to hack off the render around the crack and try to get back to the EML and effect some kind of repair i.e. a patch repair of EML nailed to the frame and then re-plaster. With regards to the window - I was thinking of taking off the internal finishing boards and checking or adding some mechanical fixing from the timber frame to the window frame i.e. a straps/bolts or whatever I can fit in and then re-install the finishing panels so the gap is no longer visible. Alternatively, I might have to end up taking the frame out and then re-fixing it completely.
Some might call this a bodge - I was thinking it was more minimal intervention... has anyone had a similar problem and what did they do and what do you think I might have to think about with this problem?
I have attached two pictures to help clarify what the heck I'm on about. Thanks for your replies....
