David Angel
I have a fireplace with a 4 foot high brick arch. Just above the brick arch INSIDE the fireplace there is a metal bar which is connected between the back and the front of the fireplace. I am about to run a liner down the chimney and it is exactly where the stove pipe will attach to the liner so it's in the way! Is this metal bar structural? Or was it used to hang a pot from perhaps so can safely be removed...
The bottom line is, can I chop it out without the stack falling down to make way for my new liner? ;-)
