realslyshady
Hi folks. Me again.
We're planning to insulate between the joists on the ground floor — once the boards were numbered, mapped and lifted (need to do this anyway to readjust some of the joists and replace others) I was going to staple garden netting to the joists at the right depth, then lay rockwool or similar to floor level, then relay the floor, using reclaimed boards to patch the many, many gaps it has at the moment. A joiner was round today to give an estimate on some other work, and he felt that mineral wool was a poor choice — he reckoned I should use Kingspan or similar, with expanding foam to fill gaps. My research had suggested this was a bad idea, but now I'm unsure. Any advice? Thank you...!
