I’ve never tried making lime putty before, so could you please refresh me on what to do.
Questions:-
Standard 25kg bags of lime hydrate from the builders merchant, Blue circle or otherwise.
Or some other specialist make of lime hydrate?
Add water to hydrate or hydrate to water?
What proportions of water to hydrate?
What type of container for the above mix, plastic dustbin, galvanized bath or dustbin or doesn’t it mater? Would old discarded vessel such as an old tin bath with a bit of rust on it affect the mix?
What should the mix initially look like before it slakes - milk, cream or porridge?
After mixing in the above vessel, how long before you have lime putty? I understand mature is better. Dose the water get absorbed by the lime and dose the mix need topping up with water from time to time?
Do you keep the unsightly container (bath) of putty lying around the house for weeks /months on end or can you transfer the mix to plastic containers with lids almost immediately (topped with water of course)?
When you come to use the putty, I guess it would be very wet having stood in water, also the sand will probably have some moisture as well. I believe the standard mix is 3 sand to1 lime putty. No water required I presume?
Many thanks
			Questions:-
Many thanks
