Lindyboo
- East Lindsey, Lincs
Well folks, it’s me again and more water worries (of the house plumbing variety). Getting well fed up now.
Moving sideways from my recent thread on rising damp – very long story since then – but it turned out that the fundamental problem was a leaking mains joint which has been weeping – and then gushing – underground. Ground and walls have been getting a soaking for potentially years hence our flood after the hurricane.
The joint was repaired a week ago and we had an immediate improvement in water pressure as expected. Since then the pressure has gradually fallen away until there’s barely enough to run appliances.
The reduction in pressure after the initial boost began within about 24 hours but for four days after the joint repair the new joint was visible awaiting the hole filling in. The joint was definitely not leaking which suggests something else is amiss. The pipe and new joint are plastic.
There’s no supply issue locally (have checked) and we share a mains with only one other distant neighbour, whose supply is normal.
I’ve arranged for our water authority to come on Thurs to check the mains supply which will tell us if it’s their end or ours, but in the meantime I’m wondering if there’s an airlock in the mains which is causing the problem?
Previous airlocks (other properties) have been obvious by the noise of trapped air and/or spurting taps. There was some minor spurting after the joint repair but none since. In the past I’ve got rid of airlocks by the usual method of attaching a hose from one tap to the other, but as far as I can recall, airlocks are usually found only in either hot or cold supply – not both, as is the case here, which suggests a mains issue.
So, after this long explanation, has anyone had a mains airlock, i.e. affecting hot and cold supply and if so how was it cleared? If I can get it cleared myself it’ll be better than waiting till Thurs for the water bod.
