Penners said:Our first repair/renovation project was over 30 years ago. It was a 15th century timberframe cottage, with pamment floors downstairs. The ground floor ceilings were quite low, and when we applied for LBC to carry out various works, consent was granted on condition that we lifted the pamments, dug out 6in of subsoil, then re-laid the pamments again.
Needless to say, this digging out did not excavate below the evel of the foundations.
The C15th building was originally built as a three-bay hall house (fabulous king-post roof structure). At some point it had then been converted into three one-up/one-down cottages. At some later date, the end that we bought (two of the three cottages) had been combined into one by creating a door in the party wall. All the walls (party wall included) stood on brick plinths, two courses above ground and four below. There were no skirtings - just the brick plinth surmounted by a sole plate.Ian Bond said:Just out of curiosity, what did you do about doors and door openings? I'm assuming that there were no skirting boards to re-fix.
It was indeed. The oak frame was of extremely high quality, although without any fancy mouldings. The only heartbreaking thing was that, when the chimney was inserted (probably Tudor), one of the four beautifully shaped king post windbraces had been partly cut away to make room for the brickwork.Ian Bond said:It sounds fabulous, particularly the king post roof.
Yup - cowboy builders aren't exclusively a modern phenomenon!Ian Bond said:Tsk - those Tudor vandals!
