Hi
I'm after some advice on my back yard, which I am sorting out at the moment.
I need to dig a french drain, as, worse luck for me, the original sandstone flags were laid sloping downhill towards the kitchen wall (laid on clinker, so I am pretty sure they are as-built). These slabs are big, so I don't think I can lift them without breaking them (or me), so they will have to stay sloping the wrong way...
I have done some initial digging to lower the soil level to below the internal floor level and slope away from the house- original outside level was only an inch or so below the internal level, so not ideal.
Plan is to lower the inspection chamber lid by a course or 2 of bricks to get the top flush with the slabs (lots of sledge hammer fun there), reinstate missing sandstone slabs towards the house, but terminate these a foot before the kitchen wall leaving exposed gravel to stop rain splash (as per the diagram below).
So the question is: will a basic french drain sufffice (I would guess this would be the usual big geotextile 'sausage' of 20mm gravel across the 2 metre or so width of the yard), or should I go for the deluxe version with a perforated pipe that somehow connects into the inspection chamber (which would then be a further headache due to the lack of room and awkward position of the inspection chamber!)?
That said, there is a 'stub' availailable in the inspection chamber to which I can connect the land drain pipe, marked on the photo below.
I have a feeling I will be replacing and slightly re-aligning the underground soil, rain and kitchen waste pipes while I can as they are a bit of a bodge too.
