charlie-ia
- LANCASHIRE
I think our house is trying to talk to us (or take over our brains) but unfortunately i dont speak its language fully yet!
after our week of exploring i have some little clues, but dont know how to use the information.
the "coal bunker" has a concrete top, which is unfortunately smashed and dangerous. in the concrete it says "Pb 1916". this is pleasant in its self, but the clue is that the concrete looks very similar material to the render on the front of the of the house. it covers the whole front and end wall, and is gently marked out to look like fine stone (ashlar?) on the front.
is 1916 a suitable date for this style?
Even though the front of the house is away from the prevailing wind, it is the joists on this side that seem to be rotted most, so we're guessing the render is stopping it breathing.
If it is from 1916 should we leave it on? is it likely that cement this old will actually breathe ok? should we just remove a few feet at the bottom?
the second clue is the outlines from the past. on the end gable there is the v of a roof , about halfway down the outside of the bedroom wall.
its clearly not an old outbuilding, because of the way the hill slopes.
the two left hand windows have moved up a couple of feet from their origonal position and you can still see a windowsil. on the right a window has been closed off as it would now be between floors (or at floor level- we havent measured yet).
on the opposite end of the building is a very high window, with glass in, but we cant find it from the inside of the house!
It may be in the loft, or behind the wall. or in the secret passage
looking at the gable i would have guessed the house was once a one and a half storey cottage with a thatch roof, possibly replaced with tin, then built into two storeys later. but then the complete window confuses me. its too high for that scenario.
I need to look into this further obviously, but what does it tell me so far?
if it was a cottage should we go for cottage style, or should the fact that its now two story be a stronger influence? there wernt many two storey houses around until recently, except for the bigger square farmhouses, so maybe the people who rebuilt went for a bit grander ideas than the neighbours?
the doors are whats bugging me at the moment, if it was a cottage then plank doors are just the thing. same as on the barn. im thinking if theyve gone to the trouble of adding a second storey then they will have probably gone a little upmarket with their new 1916 door.
on the other hand, it may have been the same farmer living there all along, just needed a bit of extra room. no fuss.
does what ive found so far tell me anything else?
