I own a 1800's Grade II listed Building, I am currently converting it from commercial to residential and have hit a bit of a nightmare with the windows. The current windows are non original single glazed sash windows, quite poorly made.
I am caught between building control and Listed building consent. For a conversion the windows must meet a certain standards and achieve a certain Uvalue. So they must be replaced or secondary glazing installed.
I've had an application in to replace the windows with double glazed sash windows, but this has been knocked back. I met with the CO last week and he stated I would have to use slim line double glazing, glazing units should be putty glazed from the front. He also said surface fixed glazing bars are not appropriate for a grade II listed building.
I met with a joiner today who makes windows and has some experience in working with slimline glazing. He seemed against using putty for several reasons and also said that if I was using multiple panes of glass ass opposed to surface fixed glazing bars it would not be possible to hide the seals on each unit with the slimline glazing bars, so there would be some of the black seal on show..
I have been provided a window sample, fitted with slimline glazing to show planning.. I'm impressed with the look of the slimline double glazing. The sample window uses chamfered wood beading to resemble putty, which I do not think the CO will go for.. but the joiner said I should try it.
Just wondering if anyone had experienced anything similar, and what solution they came up with? Also if CO might be willing to compromise on any of the above or if I am wasting my time showing him this example and should give exactly what he has asked for?
