Lynn
- Wisconsin USA
I have researched linseed oil since there is so much talk about it as making a superior paint product, filler, etc and I did a search on this site, but did not see a full explanation of the positives and negatives of linseed oil. So here is a thread to work out definitions etc.
First I found on this site_(click_here) that boiled linseed oil is not really boiled, but has additives that give it the properties we find convenient--like the paint will dry. He quotes the label of his can of linseed oil:
That seems more than "boiled".
Also in the paint department of linseed oil use, it is said that linseed oil is food for mildew. This effect was minimized in the past with the heavy dose of lead paint had on board, but we don't add that to the mix now, so this could be a big problem in exterior paint applications. In fact a recent_thread complained about darkening of the linseed oil painted trim, but there was no suggestion that this could be fungus creeping in. Also it was suggested to help white wash stick to stucco one could add linseed oil. I'm very concerned that this might lead to growth of mold/mildew.
So there are the issues I see that need to be considered as you take the step into linseed oil in restoration projects. I hope the people using this will chime in with more/better information
Let me quote the warning label from a can of boiled linseed oil...
"Use of this product will expose you to arsenic, beryllium, chromium, cadmium and nickel, which are known to cause cancer; and lead which is known to cause birth defects and other reproductive harm."
