gsport george
- Sheffield
Not been on here in a long time... actually been, slowly, getting on with things....
Wiring is fairly well advanced (not that well, considering it has been 3 years, but no point "rushing" these things..) and I am at the point of fitting some mains linked smoke alarms. Trouble is that the instructions say they need to be on a lighting circuit that is used regularly (so I notice if it has tripped/failed), but that it also shouldnt be on a circuit with any fourescent lights or dimmer switches... and shouldnt be within a metre of any flourescent lights.... This makes it pretty difficult if you count compact flourescents in that.... The way I had planned (and started) doing the lighting was one circuit per floor (cellar, ground, first, attic) with the outside lights on the same circuit as the ground floor. Attic and Cellar arent always used everyday, so those circuits are out, ground and first floors want to have some dimmers (probably) and almost certainly some compact flourescents. I had planned to put the alarms on the stairs and in the hall but all these locations are within a metre of CFLs...
Any ideas?
If I run a seperate loop of cable from the consumer unit will this be like a seperate circuit, even though it is on the same MCB? If not, what magical process takes place in the MCB that nullifies the effects of any equipment on other circuits?
Instead of CFL's I can obviously look at using low volt halogens or LED's, but will the transformers for these be OK? (ie. not interfere)
George
Any ideas?
George
