Lynn
- Wisconsin USA
I limewashed the back of our house last year as a kind of experiment and it has held up under a Wisconsin USA winter. I have lost the recipe which is a bother because I added a bit of pigment, but I think I can reconstruct those proportions.
My reading has confused me a bit though about additions to the lime and water. Many say add salt solution. Lately a person on this board chimed in to add boiled linseed oil and there was a good discussion about using purified oil so there is not food for microbes. Also I have the bag of hydrated lime from last year and it seems in some quarters that this is hopelessly old and not good for making limewash. Can I salvage it by soaking in water for a week or two (slaking it)? Last year I just mixed the whitewash and applied it. I guess this is not the preferred method of wash preparation. So I have to narrow in on the recipe if you all could provide a consensus.
And then there is the preparation of the stucco. I have read just brush it with a stiff brush, others say wash with TSP-type wash to get the molds and mildews off. It is a cement stucco from the 1920's, but I don't see any paint except limewash. All the layers I have been able to expose and test with vinegar bubble, so I think the whitewash will soak in and seems to have on the part I did last year. Cleaning it will be important, expecially on the north side of the house which is a sight.
How to apply it...wet the walls first, put it on in thin coats. How many coats is a question too. I only did one coat and the patched areas are starting to show through...the wash absorbed differently into old vs. new surface probably. I have read from 3 to 8 coats :shock: and I can't imagine doing that to a house. Even three sounds daunting.
Maybe I should title this exterior limewash 101.
Thanks in advance for your help.
