tobydog
- South Suffolk
Hi. Would appreciate some views. We recently had some work carried out on our inglenook to remove the dreaded cement render, repair the substantial hidden damage (including letting the considerable damp dry out) and rendering in lime. We also had some of the non-rendered crumbling bricks replaced with originals and lime mortared in. This is now looking great, however, we still have 4 or 5 bricks inside the inglenook that back onto the old damp areas where the bricks are simply turning to dust infront of our eyes.
When the CO first came round to look at the inglenook and some other work we were having done (house is Grade II), she recommended painting the brick faces with several coats of the water you find at the top of a tin of lime wash. We happen to have a full tin of Farrow & Ball white limewash that we hope will be perfect. Has anyone done this recently, does it work, and how many coats do I need to apply? Apparently the water absorbs into the brick and the residual lime in the very diluted water reacts with the carbondioxode in the air and forms a breathable seal with enough coats.
